Good afternoon gentlemen,
Firstly, please forgive any mistakes or typos as I am uploading from my phone. Second, this is a pre-drilled pipe from PIMO so I would like some feedback/advice more about the finishing and shaping of this pipe. This was my first time dying a pipe and it looks a little strange to me. It could be the inconsistent grain? Also, there is a vertical line on the broadside with the flame grain that I couldn't sand out. The briar also has multiple flaws. Not a great pipe, but it's a next step in a long journey of pipe making. I sanded 60 grit sandpaper to, 320, 400, 600, 1000, 2000. Red polishing compound. Then buffed with carnauba.
I appreciate any comments and could post additional photos if requested. Thank you.
Second Pipe Completed-A tilted billiard?
Grace and peace,
Ethan Gilmore
Ethan Gilmore
- Joe Hinkle Pipes
Re: Second Pipe Completed-A tilted billiard?
You can stop sanding the bowl at 600. Sand your stem up to 1000 to get it shiny and then buff. I would guess you are buffing too hard and removing too much stain.
I would recommend studying some billiards before your next attempt.
What would one buff the stem with? And I think you're right because it felt like after I applied the dye and sanded it off, I pretty much sanded back to nearly the natural color. Made it look really uneven. Thanks for the feedback.Solomon_pipes wrote:You can stop sanding the bowl at 600. Sand your stem up to 1000 to get it shiny and then buff. I would guess you are buffing too hard and removing too much stain.
Yeah, true. I need to. I'm learning how patient you have to be with hand tools to develop those shapes. Thanks for the suggestion.d.huber wrote:I would recommend studying some billiards before your next attempt.
Grace and peace,
Ethan Gilmore
Ethan Gilmore
- Joe Hinkle Pipes
buff the stem with the red compound you used on the bowl. if that is a premold stem that hasnt been touched i would sand at 320 400 and 600 then buff. it will look much better, and eventually you will have to tackle the business end of the pipe. might as well introduce yourself to it.
- Literaryworkshop
Just to clarify what's been said above, you need a powered buffer. Buffing by hand will take the rest of your life. A basic bench grinder or even a drill press can get you there.
You need to be more aggressive in taking off material where it doesn't belong. Most good pipes should look more delicate than that.
Here are my two suggestions:
1. Look at traditional shapes (or not-so-traditional shapes) and pick one that you want to make. Get that shape firmly in mind. The best way, I find, is to draw it. Draw it several times, either freehand or with some drafting tools like a straightedge and compass. When you have the target shape down, draw it out on your briar block, both top and side. Of course you'll get rid of your lines as soon as you start shaping the wood, but it will help you see where to begin.
2. Take your time shaping, and pay attention to how the whole pipe is shaping up. Keep your drawing(s) handy as you shape the pipe. Go right down to the lines and pay attention to details, especially to that pesky transition between the shank and stem. With a very few exceptions (e.g. a horn or calabash), the shank and the bowl should look like two distinct parts that transition smoothly into each other. A chainsaw file helps a LOT with this.
- Steve S.
Awesome. I will be sure to do this. Thanks, again.Solomon_pipes wrote:buff the stem with the red compound you used on the bowl. if that is a premold stem that hasnt been touched i would sand at 320 400 and 600 then buff. it will look much better, and eventually you will have to tackle the business end of the pipe. might as well introduce yourself to it.
Thanks for the response! I actually have been using a dremel tool with buffing attachments to buff. I couldn't imagine buffing without at least that. I'd love to purchase a buffing wheel in the future but that'll be down the road. In response to your first suggestion: You are the second person to advocate drawing the shapes on a sketchpad. I will have to increase my drawing time. In response to your second suggestion: Very good advice! It's very helpful to think of the shank and bowl as two distinct parts. Also, I will look into a chainsaw file.Literaryworkshop wrote:Just to clarify what's been said above, you need a powered buffer. Buffing by hand will take the rest of your life. A basic bench grinder or even a drill press can get you there.
Grace and peace,
Ethan Gilmore
Ethan Gilmore
There are too many issues with basic craftsmanship to critique this pipe.
You may need some practice with file use and sanding on the next pipe you work on. Go slow and focus on a couple things.
1. Make a near to perfect cylinder on the shank.
2. Make sure you have a smooth surface with each grit of sandpaper before moving to the next.
Quick tip for a big improvement on the next one: sand the shank with the stem attached. That way you avoid those rounded-over edges at your shank/stem transition.
Ryan Richardson
R2 Pipes/Ryan's Luxury Goods
