pipe #2 dublin
pipe #2 dublin
this is my second pipe ever. i decided to try making something like a kaywoodie #17. i changed it up a bit im not exactly sure what you would call it now but i am open to criticism and advice to make my next pipe that much better
- (118.07 KiB) Downloaded 188 times
- IMG_8890.jpg (97.48 KiB) Viewed 438 times
- IMG_3345.jpg (114.22 KiB) Viewed 438 times
- Joe Hinkle Pipes
Re: pipe #2 dublin
A few thinks you could work ok. The taper is too strong from shank to button. A good sharp line, just too steep. The bowl dips below the shank line. The angle of the top of the bowl leans back instead of forward. A few areas to start anyway.
Re: pipe #2 dublin
i made the bowl forward just to see how it looked i was pleased with the forward cant but its just a personal choice, but i see what you mean about the taper and bowl. i think ill go back and slim down the taper and bring the underside of the shank in with the bowl.
- wisemanpipes
Re: pipe #2 dublin
bend the stem. or take more meat of the underbelly of the bowl.
Re: pipe #2 dublin
i actually thought about a slight bend in the stem but wanted some opinions on it before i did it.
