Результат 2013 года.
- S. Vyzhanov
Allow to present. I hope for criticism.
Re: Результат 2013 года.
The last is beautiful.
La última es preciosa.
El mundo de la pipa
Those are great. The last one is my favorite.
I'm new at pipe making so don't put too much weight in this, but something in the bowl of the second pipe seems a bit off to me. I love the stem and shank on it though.
Keep up the good work!
Серега, привет.
Результат.... оно, конечно.... но тут English в обиходе.
А трубы - да. Классные.
- S. Vyzhanov
hello, Sasha! Thanks a lot!
And I in English wrote, but something went not so! I will be more attentive!
And thanks to all! ! !
- wisemanpipes
very cool! where are you from? looks very Russian/eastern European.
only critique would be that your stems could be thinner and possibly more defined but other than that, great finishing. your shapes are unique and whimsical.
great pipes and welcome
- S. Vyzhanov
Thanks for your opinion! Mouthpiece in a bite of 3,5 - 4 mm. I continue to work further.
The only thing I can see wrong is that the last pipe (freehand) isn't mine.
rdpipes.briar.club
- S. Vyzhanov
Itself I left it with tears in the eyes. Weight at it - 32 grams, the tobacco camera - 18 x 37 mm. Now it at my friend, he yet didn't smoke from it, passed month, and he says that she not for smoking, only admires.
Thanks for your responses! ! ! It is very grateful! ! !
- S. Vyzhanov
In the summer 2013 I tried to make stems for churchwarden. It turned out. The stalk drilled a drill in hands. The ebonite core of initial 16 mm, length is 220 mm... it was unexpectedly lucky! ! !
The pipes look very nice. One thing you can improve is to sand the tobacco chamber a little more to create a cleaner look. Also if you put a very tiny radius on the chamber rim it will prevent damage from a burnout, and I think it looks good too.
- S. Vyzhanov
Your opinion, thanks is very useful for me!
From burning out of top of a cup I did some pipes with a ring of metal (if the translator correctly translated to me, and I truly understood ). Approximately so:
- Thomas Tkach
Do you have a website?
- S. Vyzhanov
Thomas Tkach wrote:Do you have a website?
No. I just study. The website early for me as it seems to me.
Nice pipes! I really like the small sculpted apple (second pipe from the top)!
The metal ring on the inside of the rim looks nice, but I think it creates more danger than benefit. There is considerable heat in that spot and metal will expand and accumulate temperature differently than the briar around it - no matter how you set it in place it may either fall out or even crack the walls of the pipe.
- S. Vyzhanov
Thanks, very pleasantly!
And I was the same opinion, but I have two pipes with such rings which I experimented within three years, and they proved to be from very good party, isn't present cracks. And temperature low, it is possible to touch with a finger quietly.
