Hi there,
here comes my latest "masterpiece", kinda Dublin with 9mm filter :
Weight 44 g / 1.55 oz., acrylic stem, application made of horn.
A - bowl diameter: 40 mm
B - bowl height: 54 mm
C - length: 137 mm
D - tobacco chamber diameter: 21 mm
E - tobacco chamber height: 43 mm
Critique, please ...
Jens
13-05
Re: 13-05
nice one. I like how stem and wood color fit together.
You may want to change ISO and aperture (Blende) on your camera next time
Since you are in Germany, making 9mm pipes, may I ask what drill bit sizes you use for
draft hole
mortise and
tenon
draft hole
mortise and
tenon
Re: 13-05
Thanks, birba ! Yes, I know, I'm not one of the greatest photographers ...
You could as well drill the filter chamber completely with 10.5 mm, but I like it better this way.
Tenons of 10.5 mm diameter are available ready-made, and I use these.
Jens
Basically, I drill them like this:birba wrote:Since you are in Germany, making 9mm pipes, may I ask what drill bit sizes you use for
draft hole
mortise and
tenon
Jens
Re: 13-05
nice pipe,....
