these two babies are just to show them here (more pic's on links provided bellow)
ND Pipes - P5312
http://tnd-pipes.com/pipes/p5312/
https://www.facebook.com/NdPipes
This pipe was made using a piece of plateaux briar from Italy.
She has seven rings made from black acrylic rod, boxwood and padauk wood.
Mouthpiece was made using an acrylic rod, turned on lathe to roughly shape it and finished by hand.
ND Pipes - P5212
http://tnd-pipes.com/pipes/p5212/
https://www.facebook.com/media/set/?set ... 356&type=1
She has nine rings made from black acrylic rod, sapele wood andboxwood.
ND Pipes - two more - just to show
Re: ND Pipes - two more - just to show
The rings on the second one are sexy man. I LOVE how thin you cut that. How do you do that might I ask? Do you glue each layer, then face it down, then glue on the next? However you manage it... damn.
they look bitchen
rev
rev
Nice job, of course. The first one has just a little too much going on for my preference, but I like the second quite a bit. I like the style of rustication on them. Nice work.
So the saying goes: I'm not generally a fan of rustication, but this rustication is very classy. I really like it. Great work, as usual!
hehehehe - thanks... those thin ones are veneer boards...The Smoking Yeti wrote:The rings on the second one are sexy man. I LOVE how thin you cut that. How do you do that might I ask? Do you glue each layer, then face it down, then glue on the next? However you manage it... damn.
the rings... i cut those thicker ones to the measure and than sand each one of them by hand to be exactly the thickness i want them to be and even on every side... then i glue them all together,.. after this was made and the glue is hard, i drill the 10mm hole for the wooden tenon to hold those piece together better and also to connect them to the shank of the pipe better... then i glue everything together and after the glue is hard, i drill the hole (in that wooden tenon) for the mouthpiece.. (hope it is clear)...
i really have to make a photo essay on that topic...
thanks guys...
a lot
I get what you're saying! That's a sweet signature look you've developed.
thanks man
many regards
cool smokes.
many regards
cool smokes.
