Hello all. I'm fairly new to pipe making and I am glad to have found this forum. Lots of useful information and helpful people here. I hope to add a little bit here myself in time.
A little about me. I come from a boatbuilding/woodworking background, so I have a small collection of tools needed for pipe crafting-minus a lathe and grinder/buffer.
I've built 3 pipes so far, 1 from a PIMO kit, and have found it to be a very rewarding process. While they all turned out ok, and smoke fine, they aren't the best in terms of details. My sanding technique needs some work. I'll try to post a few pictures for review soon.
I've got a few questions.
Is there a "standard" size for the tobacco hole? I've machined a 3/4" spade for boring the tobacco hole, but I was wondering if anyone bores a smaller diameter? Are there any drawbacks to a smaller diameter in regards to how the pipe smokes?
Thanks in advance,
Chadd
Newbie Intro
Chadd, from what I understand there are changes in the way a person must smoke a pipe with a smaller and larger diameter. 3/4" is my preferred size and it will smoke fine. I think that you will not start to notice a difference in how you need to pack/smoke a pipe until you are over what 1.25" or so. But my experience is pretty limited but I've done a lot of reading etc. So take it for a what it's worth. I'm sure one of the pro's will chime in here soon.
Welcome Chadd,
3/4 is what I use but sometimes after some final sanding of the bowl gets enlarged and sometime I just keep enlarging because the shape calls for it.
I have only noticed that the prince and the buldog shapes have larger shallower bowl shapes.
Steve J
Opinions! Everyone has one and everyone thinks the other persons stinks
Steve J
Re: Newbie Intro
Welcome, Chadd!Chadd wrote:Is there a "standard" size for the tobacco hole? I've machined a 3/4" spade for boring the tobacco hole, but I was wondering if anyone bores a smaller diameter? Are there any drawbacks to a smaller diameter in regards to how the pipe smokes?
3/4" and 7/8" are my prefered chamber diameters, but I also have had requests for smaller chambers where I'll use a 5/8" bit.
The smaller chambers are good for people that have trouble keeping their pipe lit - it allows the incoming air to move more evenly over the lit tobacco, and keep the heat of the embers close to the unburnt tobacco. On the other hand, you need a smaller tamper to tamp in a chamber that small.
Past about 7/8", I have trouble keeping the tobacco lit. That's probably due to my smoking style more than anything though.
