Glue
Glue
I know this has been discussed some before, I have done search after search and saw many different ideas, but it doesn't seem to me to have been discussed in depth, I could be wrong.
I have been using epoxy to attach extensions to the shank. Home Depot, five minute stuff. Seemed to work great. However, the first one I did has now come loose after about a month of off and on smoking.
Damnit! Is it just the epoxy I'm using, or should I use something else. The extension was lucite, but I wonder the same about wood, bone, etc.
I read one article about using CA to do this and that it seemed to do a wonderful job.
So, would appreciate some advice, what sort of glue is best for extensions and other uses on a pipe? Is there one which is a "good for all uses" or should there be different glues used in different circumstances.
Apologize if I missed a comprehensive article that discussed this, but really did spend quite a bit of time searching.
Thanks for the help, as always.
Re: Glue
I use epoxy for shank extensions. Are you turning a short tenon on either the extension or the shank before gluing it on, or are you gluing smooth face to smooth face?
Re: Glue
RadDavis wrote:I use epoxy for shank extensions. Are you turning a short tenon on either the extension or the shank before gluing it on, or are you gluing smooth face to smooth face?
I turned a tenon on the extension which was inserted into the shank. Glue on tenon and on face where they met.
I see many different epoxies, maybe the Gorilla Glue five minute stuff ain't worth a damn?
Re: Glue
I have no idea. I use some 5 minute that I bought at Ace Hardware. I think it's called LocTite?wmolaw wrote:RadDavis wrote:I use epoxy for shank extensions. Are you turning a short tenon on either the extension or the shank before gluing it on, or are you gluing smooth face to smooth face?
Re: Glue
I have seen that brand as well. Thanks for trying to help. Maybe it just didn't mix properly, or I didn't clean area well enough. I have two other pipes I used it on, so we shall see. I haven't smoked either one yet, so can't tell.RadDavis wrote:I have no idea. I use some 5 minute that I bought at Ace Hardware. I think it's called LocTite?wmolaw wrote:RadDavis wrote:I use epoxy for shank extensions. Are you turning a short tenon on either the extension or the shank before gluing it on, or are you gluing smooth face to smooth face?
Got me reading about it though. Thanks again.
Re: Glue
What I use will depend on what I'm bonding ....
Plastic to plastic (including ebonite, lucite, delrin)
Loctite Epoxy
Dissimilar materials (lucite, etc to wood)
System 3 Epoxy
Wood to wood
Titebond III
Loctite Epoxy
System 3 Epoxy
Wood to wood
Titebond III
Kim Kendall
http://www.PenguinBriar.com/
Re: Glue
That's great, THANKS!kkendall wrote:What I use will depend on what I'm bonding ....
Loctite Epoxy
System 3 Epoxy
Wood to wood
Titebond III
Re: Glue
yep... i had the same problem with that stuff. switched to the loctite 5- min and all is well now.maybe the Gorilla Glue five minute stuff ain't worth a damn?
Re: Glue
Good to know, throwing that stuff out tonight. Thanks.sam a wrote:yep... i had the same problem with that stuff. switched to the loctite 5- min and all is well now.maybe the Gorilla Glue five minute stuff ain't worth a damn?
I wonder from the other threads I searched, does CA work as well?
Re: Glue
CA glues are good for certain applications. They REQUIRE pressure to set so if you can't clamp or push hard on something don't bother. Over all, I'd use epoxy as it is both heat and water resistant. I use LePage 5 minute.
Re: Glue
I use system 3 five minute epoxy. Gorilla was crap.
Titebond III is God's gift to woodworkers.
Andrew
www.andrewstaplespipes.com
