Full pipe making pictorial, from block to finished pipe.
Not sure if anyone here is really interested in this, since... you know, most people here see this kind of thing all the time in their own shops...
But I've gotten some requests for this, so I figured I'd post it.
I also thought it would be a good way to get some pointers on my techniques, since I am still learning, and the knowledge on this board is a resource that I greatly admire.
I thought it would be a neat idea to update this as I went along. I want to be as detailed as possible, So I'll start at the very beginning.
Most of my pipes start with an idea, usually some sort of feeling that I want to recreate for the user. And I'm thinking that this pipe will start with the idea of high altitude exploration. Standing on a windy mountaintop, pipe hanging from mouth, one hand on your hiking stick, the other blocking the bright sun from your eyes... you get the idea. I found this image a long time ago, and I think it's a good place to start..
The pipe will need a bowl cover, both to hold smoking material in the bowl in windy conditions, and protect a half smoked bowl while you're hiking. I like the idea of a very compact hinge mechanism, since it is more robust. The rest I'll figure out later...
Check back for updates daily!
Re: Full pipe making pictorial, from block to finished pipe.
Day 1, short day.
Clean shop, ready for pipe making..
Woods to be used, Amboyna Burl, African Blackwood, Padauk, maybe some red palm...
Drawing the rough shape
Cutting it out with a fret saw
Some rough sanding
Putting it on the 4 jaw chuck and turning the bowl on the lathe
Putting the drill chuck on the lathe and drilling the bowl
Setting the boring tool, and boring the bowl out to the correct diameter
Turning the base of the stem
Drilling the mortise for the stem
Boring the mortise
Completed holes for eventual stem and bowl insert
Coffee break
Rough sanding with the 4 jaw self centering chuck, and padded sanding disc
Roughing the shape out some more with a detail rasp
Refining the shape with some detail files
Some Tools
Switching to a finer grit sanding disc to smooth out the shape a bit and get rid of scratches from the rasp
I lick the wood to check the grain pattern, lookin' nice!
My hand, for scale
Another view of the mortises and partial air holes, with my safety glasses in the background
Rough block of African blackwood in the chuck, this will eventually be the bowl insert
Turning the outside diameter and the face
Drilling a hole to make it easier to turn the inside diameter with hand tools
Custom made turning tool for the inside of bowls
Bowl roughly turned
Some rough sanding
Boring the mortise
Coffee break
Some Tools
My hand, for scale
Bowl roughly turned
Day 2
aaaand we're back!
Drilling out the air hole at the bottom of the bowl
Cleaning up the inside
Special tool for cutting a groove on the inside of the bowl for the metal screen
Sanded down the bowl a bit on the disc sander to shorten it before fitting the bowl insert
Super fine amboyna sawdust
Mixing the sawdust in water for something cool later on...
More tools
Measuring the bowl depth with a digital caliper
Measuring again to determine what the length of the bowl insert will be
Marking some guidelines
Using a parting tool for the rough shaping of the outside diameter
Determining the outside diameter that the bowl insert will be
More measuring and turning
Using the left hand cutting tool to square up the corners
Using a diamond point tool to turn the bowl details
Using the boring tool to turn the rim of the bowl that will eventually be fitted with a lid later on
This is how it looks after some fine sanding with 600 grit
Cutting the bowl insert off with a fret saw
Lookin' pretty good, this block of African blackwood has a lot of nice gray tones that I like
It fits!
Now time for something stressful, connecting the air holes
First hole at 90 degrees
Drilling the air hole to the stem at an angle after lining it all up and clamping it down
Didn't fuck it up!
Drilling the air hole to the bowl
Perfect, the air hole is offset so that moisture buildup and resin in the bowl will drop down into the larger hole where it can easily be cleaned out with a pipe cleaner. This is also important for a pipe of this design, because without it your pipe would make a gurgling noise when you use it.
The air holes from the bottom
After cleaning it up with a detail file
aaaand we're back!
More tools
It fits!
Didn't fuck it up!
Having some milk, haha
Cut out a piece of copper with a hacksaw, this will be a rim for the bowl, and also hold half of the lid hinge assembly
Hammering it out
Annealing the copper with propane torch to soften it again. Hammering will harden copper pretty quickly, so this is a necessary stem when you're cold working copper.
Letting the copper cool on a bed of sawdust, the copper will react with the carbon from the burnt sawdust to create some really nice colours
Hammering it out again
After sanding on the belt sander
After more hammering, annealing, and sanding
Final hammering, going for a nice consistent pattern
Final annealing
After a light sanding with 600 grit to bring out the pattern
Bent into a ring to fit the bowl insert
Some colour experiments, using sawdust and heat
Testing the colour, nope I like the first version better
Hammering and filing out the shape of the hinge
Ready for silver soldering
Acid flux is applied to the sanded surfaces, and then silver solder slices are placed on the joint. I prefer this method of soldering to the traditional method of holding the wire in your hand because I'm less likely to overheat the copper. If I overheat the copper the color that I worked so hard to get earlier will be ruined and I would have to start over again.
All melted
Letting it cool in sawdust for no real reason other than it feels a bit like archaeology when I take it out later, haha
Lookin' good, but still rough
After some sanding and filing, I try out the fit
This angle shows the nice deep red coloring
Lookin' good!
And that was 7 hours in the shop, haha.
To be continued...
Hammering it out
Final annealing
All melted
Lookin' good!
To be continued...
Fascinating!
Please keep doing this.
+1taharris wrote:Fascinating!
That seems extremely labor intensive. Fascinating to watch. You really have me curious to how this will turn out. I can't wait to see the finished product.
This is fascinating! Please keep the posts coming. I'm looking forward to seeing the finished product!
Good stuff!! Waiting to see the end results=)
outstanding and fascinating
a pipemaking soap opera
cannot wait to see more
regards
dave
regards
dave
Very cool.
I have to say, I love watching copper incorporated into pipes.
Andrew
www.andrewstaplespipes.com
Extraordinary project, and work.
Extraordinarios proyecto, y trabajo.
El mundo de la pipa
MAN!!! This is GREAT!!!.. like it - can't wait to see more.....
- bandkbrooks
Ok. It feels like a cliff-hanger so keep the story going.
Brandon Brooks
Brandon Brooks
Brandon Brooks Pipes
http://www.brandon-brooks.com
Brandon Brooks
- HumblePipe
Wow! This is one of the coolest things I ever seen, thank you for sharing and please continue to share more of this process with us!
As a newbie with a Taig this really opens my eyes to possibilities. Thanks for sharing.
Michael Labo
I am hooked, next installment please! lol
Also really brilliant that you are showing just what can be achieved with a drill press and a small lathe!
This is incredible. I can't wait to see the rest.
-=Pride is not a sin=-
Ok Sir, you have us hooked.... Time to finish the pipe and upload more pics !
Ryan Alden
http://www.aldenpipes.com
