So yeah, I've decided to start naming my pipes...
Anyway, this is the third pipe I made (not counting the kit last year).
The block was an ebauchon from Jaume Hom, the mouthpiece is handcut from acrylic bar from Janzen.
The objective was a partially rusticated poker for a friend of mine, who traded me his Big Ben Lombok (always wanted one) for this.
There are - of course - some issues, such as a base which is nearly flat, but the pipe doesn't lean on in. Instead it leans back a bit (still stands though).
I'm actually quite proud of this one, but nonetheless I'm looking for some constructive criticism on this one.
Here goes:
(ps: that's dust on the bottom)
Mistral
Mistral
Re: Mistral
It appears as though the links are broken. No image is showing.
Re: Mistral
Massis,
I did a check of edit of your post to see it I could fix it because of a minor code error or something similar. I can't fix it that way. The free image host you are using does not provide for an imbedded image.
Re: Mistral
the links were correct but you can only see them if you've seen them on postimage before apparently.
I swapped them over to imageshack, so the problem should be fixed!
Re: Mistral
That's a nice pipe! However, I'll go with full rustication.
