The First entry, and the First pipe I ever made.. :D
Hi Guys,
I am a beginner of pipe making. And this is the first post.
I just finished my first pipe a few days ago.
I'd love to share with you, and most importantly, please give me some pointers or advises.
Thanks.
Thanks.
Re: The First entry, and the First pipe I ever made.. :D
Pretty good first pipe. The best advice I can give is make another pipe, and then another, and then another....... Repetition will correct some of the issues with this pipe.
Thanks. I will make some more.wdteipen wrote:Pretty good first pipe. The best advice I can give is make another pipe, and then another, and then another....... Repetition will correct some of the issues with this pipe.
Actually i am working on my second and third pipes.
Wow. That's a nice first.
I recommend bending the stem ever so slightly.
Nice first. My favorite view is the 2nd to last picture looking into the bowl. Keep at it! Looks like you'll be making some great shapes. Just curious, did you pick that particular shape and then go for it, or did it make it's way into your mind as you started carving?
Brian.
Brian.
Yes, that is what i am thinking about now.Tyler wrote:Wow. That's a nice first.
i draw the shape first, and cut a mask out a peice of paper.Growley wrote:Nice first. My favorite view is the 2nd to last picture looking into the bowl. Keep at it! Looks like you'll be making some great shapes. Just curious, did you pick that particular shape and then go for it, or did it make it's way into your mind as you started carving?
Brian.
i haven't got to the freehand level yet.
Peter
Not bad. Now go and make 20 more!
Wow, that's a great first pipe! You either lucked out, or you have an excellent natural eye for lines and reading grain. Lots of things could be improved, but these things are largely going to come with building skills. Fitting the shank and stem, taking more meat off nearly everywhere. A little bend to the stem. But if you make lots of pipes your skills and eye will develop. I hope you do make lots of pipes. I bet you could be a very good pipe maker.
Scott E. Thile
http://sethilepipes.com
Sysop: http://pipedia.org
That's an outstanding pipe and I want that piece of briar in the background! Pretty, pretty.
Hello, I'm #1312.
That's a really big number.
Thanks, you are so nice.sethile wrote:Wow, that's a great first pipe! You either lucked out, or you have an excellent natural eye for lines and reading grain. Lots of things could be improved, but these things are largely going to come with building skills. Fitting the shank and stem, taking more meat off nearly everywhere. A little bend to the stem. But if you make lots of pipes your skills and eye will develop. I hope you do make lots of pipes. I bet you could be a very good pipe maker.
while i was making this pipe, i noticed some faults i made. but i am lucky, this pipe turned out fine.
there are a lot things need to be improved, and i will change them while making the next 20 pipes.
thanks man.SchmidtN wrote:That's an outstanding pipe and I want that piece of briar in the background! Pretty, pretty.
Nice work on a first pipe! Keep it up!
Thanks, I will.Nate wrote:Nice work on a first pipe! Keep it up!
very good first pipe... make another one
That's a nice entry,keep it on...!
tNd wrote:very good first pipe... make another one
Thanks guys, I will.Abi Natur wrote:That's a nice entry,keep it on...!
