I thought I would name this the pipe that didn't wan't to be.. but changed my mind... Talk about a piece of work...Everything that could have gone wrong with this pipe did. Originally the shank was about 1.5 inches longer with a light (white) horn ferrule. The horn had the tennon on it and the shank the mortise.. while trying to get the proper curve in.. I ended up sanding into the tennon... so I had to cut off the end where the tenon was showing through.. next thought was bamboo... unfortunately I have no bamboo that would have fit the shank diameter.. so fiddle a little with drill bits and the stummel and I had room to fit another piece of horn.. then when fitting the first brass ring all was well until I was shaping the horn .. got too close to the brass.. so more sanding.. and picking a smaller diameter of brass.. fit.. .. but too much went wrong.. I got a piece of briar that wanted to stay briar... so it will become mine.. plan on breaking it in tonight.... mouthpiece.. luckily I had one sitting around since Sas convinced me to change the shape on my other blowfish..
Weight 29 grams
Length 5 1/2" 140mm
Width 1 1/16" 29mm
Height 1 3/4" 44mm
Bowldepth 1 1/2" 37mm
Briar 1 : James 0
Re: Briar 1 : James 0
LOL.... had one of those too. My wife came into the shop and asked why there was a "pipe on the floor". I told her it was in pipe purgatory, there to languish until I threw it out. I had tried to smash it into a thousand pieces, but briar just goes "clunk" when you throw it. Very unsatisfying!
Almost chunked it to tell the truth.. but decided to just try and keep it for me.. and I must say.. smokes like a charm...
I think half the fun is working out what to do when things don't go according to plan, I have a box with some 'not quite right' stummels that I go back to every so often. This can lead to some lead to some odd shapes and combinations which is part of the fun.
David.
David.
