P2011
P2011
regards
- baronstrasil
Re: P2011
very nice pipe and when i see first photo i say - Vincent Van Gogh !!!!!!! style curly )))
btw: i very like V.Gogh - i like his style paint
P.S.PIPES | http://www.slazanski.com | skype: baronstrasil | email: baronslyzo@gmail.com |
Re: P2011
i agree - she is a bit unusual
- baronstrasil
Re: P2011
but its very nice!!!!!
Re: P2011
thank You dear Sir
Re: P2011
Beautiful pipe (although it isn't your best)
Maybe a slightly more pronounced transition would be great
Greetings,
Ramón
_______________________________________________________
There are two things you need to reach happiness and peace: a swiss knife and masking tape
Ramón
Re: P2011
thanks
Re: P2011
Very nice pipe, I like the rim around the bowl.
What is the shank extension made of ? Its beautiful
Ryan Alden
http://www.aldenpipes.com
Re: P2011
shank extension is made from palm tree wood... yes - nice but a bit problematic to work with - black parts are hard as hell and brown parts are softer so some aditional attention when working with it is needed....
regards
regards
Re: P2011
I thought that was palm, but the grain looked different than what I'm used to.
Great work
Great work
Ryan Alden
Re: P2011
ATTENTION!!!! experienced pipemakers needed!!!
i need an opinion... a friend on one other forum suggested that the shank of this pipe is to short... from my point of view it is just right as the shank visually ends on the saddle of the mouthpiece... so, no need to change it... or am i wrong here??!
the change would be needed if the mouthpiece is without saddle - this way the shank would have to be a bit longer - visually...
right??!
right??!
- baronstrasil
Re: P2011
dear friend
Think of it as only my personal view of things - but maybe a bit more would help the overall concept - curved line should be highlighted more - if you send furious preview a piece of my vision:)
the beauty of thy pipes but this does not detract from the beautiful and such as ....
this is only my amateur opinion dear sir
Re: P2011
The shank is a bit short, but you balanced that out with the use of the palm extension and the saddle stem.
Personally? The bowl is a bit "chunky", and slimming it down near the shank will help give the shank a little more length.
The shank could be longer, but it's a rather minor thing at this point, so I wouldn't sweat it. Just keep it in mind for the next pipe.
Re: P2011
thank You Kurt ...
i was thinking - if i just removed a bit more material on the backside of the pipe (the side that is closer to the mouthpiece) - to remove the curve on the first white ring (i have material to do that) - it would look better for sure....
anyway - it is not a big deal - it is a big pipe - i like big . . . . . . errrmmm ... pipes hehehehehehe....
anyway - thank You dear Sir will be watching to solve this on my next one
regards
daniel
regards
daniel
Re: P2011
Superb pipe.
Magnífica pipa.
Magnífica pipa.
El mundo de la pipa
Re: P2011
thank you Felix
regards
daniel
regards
daniel
