Old Dublin by CP
Old Dublin by CP
Comerades",
inspired by some old stile pipe shapes i carved me this semi-straight Dublin in some elderly olive wood.Hand cut stem is out of some ebonite cumberland dark blue with a tapered bit.I placed the rather entwined grain on the shape as geometrically even as possible.
Feel free...
Feel free...
Re: Old Dublin by CP
Abi my friend this looks wonderful... i like everything about this pipe... it is nice and it is Dublin ... one more is spinning in my head also... soon, my friend, soon
congratulations - really nice....
It really is beautiful!
One thing that appears off is where the stem meets the stummel. It looks as if there is a small gap in places, as if the stem were not installed when sanding. Otherwise, looks like a very organic shape, the stem looks very complimentary to the design. Nice work!
I appreciate you thought on this Daniel .
I generally do all my sanding with a mounted stem(how else) ,as of the gap you mentioned and i see what you mean that appears on the side of the junction on picture no.4 (by the way do not understand my explanation as an excuse for poor craftsmanship ) There is a rather strong contrast between the grain color,the not so perfect angle of light i sometimes use on some shots and the rather large downscale of my photos from the original.
This pipe has been made for a store and a gap is of course a no-go by my little book of pipe carving .
Olive wood provides an excellent grain. Restistencia not know the fire, and life time of a pipe made from this wood, because I never had any. Could you comment on this?.
In Spain, there is a craftsman who produces olive wood pipes.
http://www.bpipaclub.com/articulos.htm#Castano_
Greetings.
Felix
Greetings.
Felix
El mundo de la pipa
Once again: A beauty!
Very well done, Genosse Abi
Cheerio!
Walle
Cheerio!
Walle
Pipes That Make You Smile
www.blue-lobster-pipes.com
I'm not a fan of the bit. However, everything else about this pipe I LOVE. As it was said already, it's a very organic shape. This pipe could smoke like total crap (though I'm sure it smokes great) and I would still enjoy just looking at it.
Hola Felix,maxmil wrote:Olive wood provides an excellent grain. Restistencia not know the fire, and life time of a pipe made from this wood, because I never had any. Could you comment on this?.
Greetings.
Felix
le agradezco su pensamiento sobre este tema!
I followed the link and read IT with great interest about the pipe maker scene in Spain.The article about Luis Castaño was very insightful.There is of course difference in olive wood like there is in Briar .I must add that the olive wood i use for my pipes go through thorough and rigid controls as i search, cut & cure my olive wood personally .
When i carve a pipe i always compose the grain carefully on the shape,i do not like to pick randomly a piece of wood and just place the shape onto it.There must be some even geometry that can be recognized on the finished pipe and it has to be placed by the creative will of the carver and not by luck. The specific density and structure of the olive trees that grow in this region on the stony ground makes it after the curing process to great smokers as it gives some smooth sweetness to the smoking experience.
There is always the question on fire resistance of the material used and broad discussions are debated here and elsewhere.
Here i will post a picture of two of my olive wood pipes that went through a endurance test for almost 2 years smoked almost every second day by a client of mine.
The pipe on the right has a bowl 2,2 cm wide and 2,9cm deep with a wall thickness measuring 8mm and both are with filter bores .
As you can observe the intense use by the rimm of the bowl, the rest of the pipe is clean and free of any irregularities like cracks,burn-through etc,etc.
I never had one complaint from any clients yet who smoke my pipes,and that is the reason why i am rigid in my control of the wood quality.
The wood is very dense and a bit heavier than Briar , kind of oily as my files and sanding tracks tend to fill up rather fast.
Here you can find some more details on the olive wood i use ; http://www.fumeursdepipe.net/pipiersNnatur.htm
I hope this will answer your question.
Magnificent response. Thanks.
Greetings.
Felix
Greetings.
Felix
Abi Natur wrote:Hola Felix,maxmil wrote:Olive wood provides an excellent grain. Restistencia not know the fire, and life time of a pipe made from this wood, because I never had any. Could you comment on this?.
Greetings.
Felix
I followed the link and read with great interest about the pipe maker scene in Spain.The article about Luis Castaño was very insightful.There is of course difference in olive wood like there is in Briar .I must add that the olive wood i use for my pipes go through thorough and rigid controls as i search, cut & cure my olive wood personally .
When i carve a pipe i always compose the grain carefully on the shape,i do not like to pick randomly a piece of wood and just place the shape onto it.There must be some even geometry that can be recognized on the finished pipe and it has to be placed by the creative will of the carver and not by luck. The specific density and structure of the olive trees that grow in this region on the on stony ground make it after the curing process to great smokers as it gives some smooth sweetness to the smoking experience.
Here i will post a picture of two of my olive wood pipes that went through an endurance test for almost 2 years smoked almost every second day by a client of mine.
The wood is very dense and a bit heavier than Brier and kind of oily as my files and sanding tracks tend to fill up rather fast.
El mundo de la pipa
Genosse Walle,Walle wrote:Once again: A beauty!
Cheerio!
Walle
I appreciate your thought and trained eye !
As of the rest of you 'miserable competitors' (which i am part off) , i appreciate your comments
Chererio '
- VaVa-Bangkok
Hey
This is very beautiful pipe you are make I olive wood, all your pipe have a great shape, but I don’t know the wood you are using are special, because it is very beautiful. I have order olive wood from Edelholzverkauf in Germany, and looking forward to see what are coming, after looking all your olive pipe, I think olive wood are interesting for pipe maikig
Carsten
Carsten
VaVa Pipe Bangkok - Thailand
http://www.vava-pipe.com/
I appreciate your thought on this Carsten,VaVa-Bangkok wrote:Hey
Carsten
you can find some more detailed answers on the olive wood i use in the reply to Felix above and the link posted.Olive wood has a long tradition as a pipe material from this part of the world were the olive tree grows for thousands of years but forgotten in time since there were less and less pipe carvers.
Edelholzverkauf is a excellent choice ,a fellow college Dotter bought also some Greek olive wood from this shop and was satisfied with the overall quality and grain.Fell free to ask me on technicalities that could occur with the wood you ordered.
