I have been making pipes for about two years and wear a good dust mask ($2.30 each) and work on a bench outdoors for the shaping and sanding. I still get dust and it bothers me at times.
Any suggestions as to what I can use to eliminate more of the dust?
Never tried to use a paint respriator, etc. only a good dust mask.
Thanks! Patrick
Ref: Pipe making wood dust etc...
Re: Ref: Pipe making wood dust etc...
Nothing beats a good dust collector.
I run an ambient air cleaner in the shop - this is just a big filter and fan box that cycles and cleans the air. There's never any build up of dust in the air that way.
Also, if you take to wearing a leather apron, it keeps a lot of dust out of clothes. I find my clothes carry a lot of fine dust and I notice it if I don't blow off hard with the air hose.
I use a dust collector and I wear 3M filter mask - aka respirator. It's the kind made of plastic and rubber with two big filters on either side. I've never had a problem with dust while wearing it, and the one time I didn't have filters for it and wore just plain dust mask, I had a horrible time with briar dust in my nose and lungs.
Great! I will start using a respirator and being that I am outside it should help even more.
Thanks!
Thanks!
- stummel bum
A respirator is pretty hot and sometimes uncomfortable, but it works great, so I love it. Also prevents the fogging up of safety glass like dust masks do (for me anyway).
Cheers,
Rob
Rob
- LexKY_Pipe
I use a respirator as well. even with good vac system dust escapes. I only use respirator when sanding with wheels.
- Vermont Freehand
After taking the EPA "certified renovator" course for lead paint work, I would recommend a N-100 dust mask, about $10, would be sufficient and not have to spend $30 on a respirator. If it's good enough for lead dust, it's good enough for briar dust
