![Image](%5Bimg%5Dhttp%3A//i166.photobucket.com/albums/u95/4gabe/101_0269.jpg)
[/img]
![Image](http://i166.photobucket.com/albums/u95/4gabe/101_0280.jpg)
![Image](%5Bimg%5Dhttp%3A//i166.photobucket.com/albums/u95/4gabe/101_0281.jpg)
![Image](http://i166.photobucket.com/albums/u95/4gabe/101_0273.jpg)
I plan on taking this pipe to a shop and have them critque it as well.
I know I still need to work on my photos sorry
Those are excellent. But if you don't have one, you can always use your hand, like here.pierredekat wrote: I've actually thought about starting a thread here on the forum about vintage tools that are extremely helpful making pipes, even in the age of powertools. The next on my list would be a marking gauge.
Man, talk about an easier way to maintain a centerline on a block of wood. I'm currently toying with the notion of making one of these things, except that, instead of having a metal point to scratch/indicate a line, it would have a pencil point, with a screw holding the pencil in-position.
Hey Rad,RadDavis wrote:Hey Jeeper,
I sand my shank faces smooth to 600 grit by putting the sand paper on a piece of flat finished granite. You can also use a piece of thick glass. Just make sure it's a flat surface.
After you've cut the shank face perpindicular to the mortise, put it flat on the sand paper and draw it toward you, keeping it flat the whole time. I do 5 strokes, turn it around in my hand and do 5 more at 300 grit. Then do the same thing at 600 grit, and you get a nice smooth finish on your shank face. When you stain it and wipe it off with alcohol, it looks just like the rest of the finished pipe.
