Phantom of the Opera
Hi All, hope you are enjoying the summer.
The name for this pipe came to me after it was finished, it seemed quite obvious. After I took the picture I decided to precarbonize the bowl. On several pipes I've had problem controlling the stain, causing runs.
Any coments?
Tano
Any coments?
Tano
It's difficult to judge based on one photo. However, from what I can see:
- the stem/shank junction is very tight
- the stem ring is the perfect size (is that olive wood?)
- great choice on colors, great contrast between stem ring and bowl
I was going to comment that the shank/bowl transition could be sharper, but on this pipe it doesn't seem to be too much of an issue. It seems to fit in with the rest of the shape. But like I said, a single photo isn't enough to draw any real conclusions.
That is not a bad looking pipe. How many pipes had you made before this one? My only suggestion would urge you not to be afraid to take off more wood.
John
www.crosbypipes.com
www.crosbypipes.com
- achduliebe
I will also echo all the previous statements. You have some fine compliments from some great pipe makers there.
Great looking pipe, I really really like the staining as well as everything else about the pipe. Nice job.
-Bryan
www.quinnpipes.com
www.quinnpipes.com
Tano, that's gorgeous! Really fine. As for you question to Kurt, I don't know, but what a lot of people would use is Florist's Clay (or florist's gum) which is kinda sticky but wipes off nicely. Great stuff for photography use.
-- john
http://justapipe.com
Very nice, Tano. That pipe has a lot of character! I like it.
I use a pipe cleaner to hold the pipe for pics. I stick both ends of one in the stem and form a loop at the bottom to hold up the pipe. Not a great solution, but it works and doesn't detract terribly from the pipe.(I usually crop most of the pipe cleaner out of the pic anyway!)
David
David
A pony clamp:
Useful for holding thin things together, or as an extra set of hands.
In all my photos, the pipe is actually resting on a curved white posterboard background so that there's no distractions of shadows back there. Also, the shadows under the pipe don't exist (largely) because of the light diffusion tent I use.
