YABA
YABA
Yet another billiard attempt.
Don't be shy about your critique. And you don't need to go easy on me. I should know better.
Re: YABA
Shank dips on top and the stem is a bit long for "proper" proportions although I think the long stem looks good here. I really like the craggy blast. Looks like a chunk of asphalt or lava rock. I like it.
Re: YABA
One of the critiques I had gotten on a recent billiard is that it was too cylindrical. That may apply here as well. Though it's a good looking pipe to be sure.
Re: YABA
I think you're on to something, and really close to an issue that hasn't been stated yet. But cylindrical isn't the right thing. The clue is in answering the question: what makes it appear cylindrical from certain angles?JMG wrote:One of the critiques I had gotten on a recent billiard is that it was too cylindrical. That may apply here as well. Though it's a good looking pipe to be sure.
Re: YABA
You got it, though the right side is flatter than the left. This, along with the top of the shank are due to novice blasting technique.Alden wrote:Left and right sides of the bowl are straight.
There's at least one more thing I know is wrong.
- baweaverpipes
- The Awesomer
Re: YABA
As for the dip, shit happens when blasting! Ever see what J.T. Cooke does with a shank?wdteipen wrote:Shank dips on top and the stem is a bit long for "proper" proportions although I think the long stem looks good here. I really like the craggy blast. Looks like a chunk of asphalt or lava rock. I like it.
Re: YABA
I think overall the pipe works, however if you were shooting for a classic billiard you missed the mark. I'd call this more of a stack. if the stem and bowl height were shortened and the bowl given a bit more contour it would be a billy for sure. Looks like a really nice pipe though. Good job.
Re: YABA
I know what you mean. I made a bulldog recently and blasted the taper off the shank. I didn't account for it.baweaverpipes wrote:As for the dip, shit happens when blasting! Ever see what J.T. Cooke does with a shank?wdteipen wrote:Shank dips on top and the stem is a bit long for "proper" proportions although I think the long stem looks good here. I really like the craggy blast. Looks like a chunk of asphalt or lava rock. I like it.
Re: YABA
Your button is still too thin front to back. A couple of good maintenace buffings and it is going to dissapear. It could also be a touch taller. Look at the slot compaired to the botton height. It looks like there isn't even anything to get your teeth on. It also looks like the pipe might wag a bit when clenched because of the lack of button, so to speak.
I know I don't make my buttons and bite zones as small as others here, but they are George approved, FWIW, and I know that after 20 years of use they will still be there.
Re: YABA
I have started making my buttons a bit larger. I made this stem originally a few months ago, so that's why it's still small.scotties22 wrote:Your button is still too thin front to back. A couple of good maintenace buffings and it is going to dissapear. It could also be a touch taller. Look at the slot compaired to the botton height. It looks like there isn't even anything to get your teeth on. It also looks like the pipe might wag a bit when clenched because of the lack of button, so to speak.
And there won't be wag on it because the bite zone is flat and the button is curved. That combination allows for comfortable clenching in a variety of different positions. I've had wobble in stems before, but flattening the bite zone and curving the button solves that problem.
Re: YABA
As mentioned, an attractive and well made pipe, and sitting somewhere between a vertically walled pipe and a curved-walled pipe, and it's just a little uncomfortable because of that, but lots of people will look at the pipe and immediately want to buy it, so there is that too. Chasing these ideals is good practice, and when you nail it, you've learned some really good skills, and in the meantime, pipes like this are perfectly acceptable to a very large number of clients.
- Joe Hinkle Pipes
Re: YABA
The lack of "body" on the bowl is the most obvious to me. Also the stem looks like it gets larger at the button.
Re: YABA
I think most everything has been covered already, but I would like to pick one little nit. I don't think the square stamping area looks right- especially when it's in the middle of the shank, and not say on the edge of the blast right by the stem. You might try adding some curved edges to your smooth stamping area?
Re: YABA
For me it is well elaborate and proportionate.
Para mí está bien elaborada y proporcionada.
El mundo de la pipa
Re: YABA
Does anyone know what the golden proportions of the various types of pipes ?. I would like to know.
¿Alguien conoce cuales son las proporciones aureas de los diversos tipos de pipas?. Me gustaría saberlas.
El mundo de la pipa
Re: YABA
Joe:
You're right about the lack of body. I'm not sure what you're seeing on the stem, but I'm pretty certain that the stem is 100% straight from button to shank.
Yeti:
Thanks for the advice. Normally, I would make the area closer to the edge of the shank, but on this one, I reworked a pipe I had already stamped and needed to blast away the old stamp. The stamping area has slightly rounded areas, but I think you're right and more rounded corners would help.
Sas, I appreciate the comment. I often feel like tossing my work in the trash when it's like this. But what you say is right. A lot of people don't notice or care about flaws that we pipe makers strive to eliminate.
Yeti:
Re: YABA
Daba Doo!
