This pipe has nearly no grain in most areas. After trying twice as some sort of stain and having to completely resand the entire thing I decide it was just going to be natural. Not sure you guys will be a fan of the tapered shank. It was a pretty fun little pipe to make. I'd really appreciate any critique you guys could offer.
A bit of the previous stain that is being a butthole and not wanting to come out is visible here...it shall be remedied.
Stem looks a bit crooked in the pic. Checked it and it's all straight, just weird in the photo...
Egg/ball?
Re: Egg/ball?
Nice and well executed.
Bonita y bien ejecutada.
El mundo de la pipa
Re: Egg/ball?
The biggest thing that I see that would improve the smoking quality is to cut your slot much deeper. It should look more like this:
Granted the slot on this pipe should be a bit wider but you get the idea. Don't make your stem airways like a factory pipe where the slot is real shallow and the airway where it meets the slot is restricted. It's one of the major things that differentiate the quality of an artisan pipe from most mass produced pipes. It's also one of the main improvements one can make to a pipe to improve the quality of the smoke and how well a pipe handles moisture.
Re: Egg/ball?
I found that when I learned to cut a deeper and wider slot I eliminated any gurgle and moisture problems, this is good advice, Norm.wdteipen wrote:The biggest thing that I see that would improve the smoking quality is to cut your slot much deeper. It should look more like this:
Re: Egg/ball?
Definitely agree with Wayne. Get you a jigsaw blade and grind down the back of it so it comes down to a real narrow point. Put that in a handle or wrap some tape around it and get in there and open that slot up.
Ryan Alden
http://www.aldenpipes.com
Re: Egg/ball?
After opening up the airway like that, how do you go about sanding the rough down? Files?
Re: Egg/ball?
Files. Sandpaper. K31 zigzag saw. Whatever you can get in there to do what you want it to do.
Ryan Alden
