I'm making a freehand pipe with wenge wood on stummel. It was my first shape-first pipe, and everything gone well with drilling.
I want to ask if it's ok for the smoke to pass through wenge wood or I should insert a metal rod such as bamboo pipes.
Wenge wood on stummel
- archaggelosmichail
- WP_20140620_006.jpg (84.27 KiB) Viewed 2473 times
Re: Wenge wood on stummel
Wenge is not safe to use for pipes. I think you'd be best off with a metal tube.
I have seen pipes made from it, However, I would do as Sandahl suggest, and run a metal tube through it. Better to be safe.Its' a killer in dust form. Goes for Central Nervous System. Splinters from it can cause Septic Shock.
