The Pipe of The Golden Heart
Starting something new, video documentation. Not sure about it, but here it is.
http://www.youtube.com/watch?v=R5h1WfmBVkA
You may need to copy and paste that into your browser, does anyone know how to get video links to work on this forum?
Re: The Pipe of The Golden Heart
Pretty sure you can just put the R5h1WfmBVkA bit between the youtube tags. If you quote my post you can see exactly what it looks like.
Hello, I'm #1312.
That's a really big number.
Well holy crap. I've been trying to figure that out for over a year.
Neat pipe, btw.
Neat pipe, btw.
Awesome, thank you!SchmidtN wrote:Pretty sure you can just put the R5h1WfmBVkA bit between the youtube tags. If you quote my post you can see exactly what it looks like.
Nice! But how'd you get the air hole through the curve in the shank of that?
Its professional grade termites. They're smarter than regular termites, so you can train them where to go
Andrew
www.andrewstaplespipes.com
I have actually thought about termites as a way of making curved holes...
Curved holes...ohh curved holes... how can I drill you?
This time around, I shaped the stem rough, then, using a jewelers saw with a tiny kerf, I cut the stem in half, tracing a dark band in the wood so that the glue line would be hidden in the pattern of the grain. I then drilled the holes from both directions in both curved halves, 4 different hole angles to drill. And then I drilled a larger mortise hole in the two halves so that they could be connected again with a bamboo tenon on the inside. This was a tough hole to drill, because the hole had to go into the two halves of wood at different angles, if it was off just a tiny bit, the two pieces would never fit back together perfectly, and the effect would be ruined.
It turned out pretty good, but my eventual goal is to just figure out how to bore a hole in a solid piece of wood with multiple curves in it... it must be possible...somehow...
There was some discussion on "drilling around corners" a little while ago. You might find the discussion on this thread interesting: viewtopic.php?f=18&t=8169meathod wrote:I have actually thought about termites as a way of making curved holes...
I really like these pipes you make. This one is just as cool as the last few you've posted.
Nicholas Burnsworth
Boulder & Briar
Boulder & Briar
Saw this thread a while ago. The problem with the steam bent method is that it's really hard to get complex double bends, or a small radius. Also you are somewhat limited to using species that bend well, which...tend to be rather boring in my opinion.McKay wrote: There was some discussion on "drilling around corners" a little while ago. You might find the discussion on this thread interesting: viewtopic.php?f=18&t=8169
I've looked at the patents for the curved hole boring machine, and it seems viable, but only for a single curve in a stem. I'm more interested in double bends.
Thanks for sharing, I was scouring the pics looking for a seam.
Yeah, hopefully he stores it in a cool dry place.Traveling Wilbury wrote:Thanks for sharing, I was scouring the pics looking for a seam.
Hello, I'm #1312.
Could you elaborate?SchmidtN wrote:Yeah, hopefully he stores it in a cool dry place.Traveling Wilbury wrote:Thanks for sharing, I was scouring the pics looking for a seam.
I was under the impression that cocobolo has excellent dimensional stability. Which is why it is used often in making knife handles, etc...
Oh, sorry. Haha....
His handle is The Traveling Wilburys. They're a supergroup from the late '80s. One of their songs I like the best is called Cool Dry Place. I was just making a joke.
Hello, I'm #1312.
Hahahha, ohhhhh. Okay.
It was that or handle me with care?
