Egg
Egg
Hi All
The original idea was to make more of a brandy shape, but there were several flaws that said otherwise. The shank extension is Osage Orange and the detail is Wenge. Let me know what you think.
Jim
Jim
Re: Egg
You are a true craftsman. You became a really great pipe crafter over night. If I ever make just one pipe that looks as nice as this, I will be a happy man! Very handsome pipe indeed!
- Mike Messer
Re: Egg
Ouuuu, now that's a nice pipe in every detail.
Mike Messer
http://handmade-briar-usa.com
Re: Egg
the shape is really nice .. i like it ...
one thing that i would like to change is the stem - i would like it to be more bent.. only that...
(but this is my taste so do not bother to much about it) - the pipe is really nice....
Re: Egg
Very nice pipe and very cool design. I especially love the stem design. I think it could be a bit more sleek/slim but it's still good and I think the bend is spot on as far as the degree goes. There appear to be some sharp angles with the bend but not bad. This is due to uneven heating of the stem or bending the stem before you have it thoroughly heated. It happens. I like to do some fine tuning of the stem shape after bending with sand paper to smooth things out. There appear to be some very minute symmetry issues with the bowl from side to side and at the heel but it may just be the photos. Either way, that's being nitpicky. Bear in mind that I tend to critique a pipe to the standard of a Bo Nordh since that's the level of quality we are all aspiring to. Your pipe is outstanding and one of the best I've seen posted as of late. Nice work.
Re: Egg
Hi Guys,
Thank you for the complements. This was kind of a departure for me in that I wasn't just copying someone else's design, but tried to impart some of my own ideas, so it is really nice to hear that I am headed in the right direction.
@ wdteipen... Thanks, both for your input and complements. Those are some good tips. I had worked on the symetry quite a bit, but this seems to be one of the more difficult things for me. It is amazing how much difference 1/32" can make!
Thanks,
Jim
tNd wrote:one thing that i would like to change is the stem - i would like it to be more bent..
I agree there is something "off" with the stem. Maybe if it was tortoise shell acrylic I could keep the shape but give it a lighter feel.BeatusLiebowitz wrote:I'd prefer a thinner stem
Thanks,
Jim
Re: Egg
Great pipe, really beautiful. Good job.
Maybe that thing off with the stem is due to the human eye is prone to complete the lines that aren't there, in this case we could be seeing a bulb form in the joint of shank and stem that isn't there.
Greetings,
Ramón
_______________________________________________________
There are two things you need to reach happiness and peace: a swiss knife and masking tape
Ramón
Re: Egg
Thanks for the input R.H.. Things tend to look a little different in the photos than in reality, but it could be, as you say.
Thanks,
Jim
Thanks,
Jim
Egg
Good work Jim. It's a graceful shape and the stain color works well with the colors on the shank extension. How was the wenge to work with? It's a really pretty wood but every account I've read is that it more less tries to kill you. I'm still a little scared of it.
Micah
Micah
Re: Egg
Micah,
Thank you for your comments! I don't think Wenge is any harder to work with than teak or imbuia. It is REAL dense so you need to use sharp tools, which will get dull a little quicker. The worst part about it is that you get a lot of little splinters. I imagine that if you use a crappy blade (HSS with set teeth) or you try to "jam" it through your saw (push it hard enough to slow the blade), then it could get unhappy, but if you use a good blade and some common sense it should be fine.
Hope this helps,
Jim
Hope this helps,
Jim
