need help analyzing this...
hey fellas... I need help identifying some things about pipes that I've been looking at. Look at this pipe:
I've noticed something that I like in people's pipes that I'm not sure I have properly identified in order to duplicate it. The simplest way I know how to put it is that they make it look like the shank/stem flow comes from underneathe the pipe. I'd like to know from you all identifiable features pull this off? Is it a high stummel? A curved shank? Is the "lowest" point of the shank real far forward? I just don't feel like I can quite put my finger on it.
If you want another example just let me know and I'll go get another...
The airway is drilled at a slight uphill slant from the mortise and the shank is then carved around that.. Think the opposite of a hawkbill.
Imagine the Blue line being the drill for the Mortise and the Black lines being the drill path for the tobacco chamber and airway...
John
www.crosbypipes.com
www.crosbypipes.com
After re-reading your post I think I may have misunderstood what you were asking. There are a couple of things that I think are appealing aspects of this design.
First is the way that the lines flow smoothy from the front of the bowl to the end of the stem giving the pipe a very solid visual feel. I usually refer to it as "monolithic".
The bowl being supported by the shank gives a feeling of floating and fine balance which in turn brings to mind the idea that the pipe is light in weight and is finely tuned or crafted.
So what you end up with is a pipe that not only looks very solid with flowing, sorta jazzy, lines but also feels (visualy) very lightwieght and well balanced.
John
www.crosbypipes.com
www.crosbypipes.com
But on the straight, you still see what I'm saying don't you? The shank appears to be the underside of the bowl.Ignoring the straight, the common element is that the inflection point where an inside curve changes to an outside curve is well behind the bowl.
That's a good way to put it.The bowl being supported by the shank
