Hi all, FatRAT here.
Just finished my first pipe. Had a blast making it, and even more fun smoking it! I spent a lot of time getting the smoke and stem hole right so there would be no abrupt transitions. To that end, I left a small gap (<.005 in.) between shank and stem so the tenon face would seat against the mortise face to eliminate any possibility of a gap in there. Also used a tapered drill in the stem. Seemed to work, smokes great, no gurgles!
My briar block was not of the highest quality. I ended up with black spots all over and an open flaw on the shank. C'est la vie.
Please comment, criticize, etc. I want to get better!
Thanks!
FatRAT
My First!
Thanks for the comments, please keep them coming.
The area that I struggled with most was the stem to shank junction. I wanted to make a fancy spacer of some sort between the two but was in a rush to finish my first. The stem is made from a blank I got from PIMO. 3/4" dia to start, turned down and faired to .640" dia., existing smoke hole opened with a .156" dia. tapered drill (for woodscrews). I also opened up the button hole considerably all in an effort to decrease smoke velocity.
Here are a few more views:
FatRAT 1 Redux
I didn't like the shank/stem junction. Just seemed to plain and the shank seemed a little long. I solved both problems by making a brass ring, gold plating it, and bonding it to the stem. It was a bit nerve wracking to chuck the stummel up in the lathe and turn the shank down. Took a while to indicate it true before turning. Here's a before and after:
It looks great in person. What do you think??
FatRAT
FatRAT
