All good evening. Today has finished here such billiard.Other photos on a site www.senatorov.lv
Pipe Senatorov ¹26
Pipe Senatorov ¹26
Pipe Senatorov
www.senatorov.lv
www.senatorov.lv
At last work the bowl was done completely in manual. Today since morning has looked at a photo of last tube as I with photographed it and has decided to make a copy in the afternoon today and by the evening I shall lay out, and that color was not so well transferred something.
Pipe Senatorov
www.senatorov.lv
www.senatorov.lv
Your work is excellent as usual. The pipe is very nicely shaped. I
actually like the sharp transition between bowl and shank, but I'm
definitely not an authority. Any detail you would divulge about what methods you use to achieve such a remarkable finish would be greatly
appreciated. What grit do you sand to? What type of dye? Do you use
more than one dye and when are they applied? thanks, Scot
I do finish so: I grind a pipe up to ¹ 800. Then I take black Stains and 10 minutes without interruption rub a pipe. After that the pipe dries a floor of hour. Then I grind a pipe ¹ 1000, it is necessary to grind it is very cautious and as soon as that will start to be shown light fibres pass on ¹ 1200,1500,2000,2500.¿ then I cover any light Stains. Then with pure flannel circle I polish, then I take one more flannel circle but already with wax Carnuba. Well and all. If something have not understood ask, I shall answer.pennsyscot wrote:Your work is excellent as usual. The pipe is very nicely shaped. I
Pipe Senatorov
www.senatorov.lv
www.senatorov.lv
Well that such contrast has turned out is necessary long studies. At me yet contrast very well turns out, and here at my teacher it turns out simply perfectly. Here a site of my teacher, look as at it contrast turns out. www.pipeatelier.spb.ru
Pipe Senatorov
www.senatorov.lv
www.senatorov.lv
Senatorov, The link did not work for me. Let me see If I have understood your directions correctly. Here is how I intend to finish my next pipe:
1. sand the pipe to 800grit
2. apply black stain
3. rub in for 10 minutes, let dry 1 hour
4. sand lightly grits 1200 1500 2000 2500
5. apply light colored stain, let dry
6. buff with tripoli
7. buff with white diamond
8. buff with carnuba
is this the correct process?
do you use alcohol based furniture stain?
thanks for the great information, Scot
6 item is unnecessary.And other all is correct . But 1000 grits it is necessary to rub before occurrence of light fibres and at once to pass on 1200 grits well and so on. You show me a photo after 1000 grits and I to you shall tell enough or not.Yes I use furniture stainpennsyscot wrote:Senatorov, The link did not work for me. Let me see If I have understood your directions correctly. Here is how I intend to finish my next pipe:
Pipe Senatorov
www.senatorov.lv
www.senatorov.lv
