Pipe # 5 Ball/Tomato
Yes, you're right kkendall. I'm still honing my stem/stummel skills. The stem fits snug with the shank but their is a gap between the white lucite and stem that you can't see in the pictures. I didn't notice it until after the epoxy dried. I masked it some with epoxy filler but it's still noticeable on close inspection. I was disappointed to find two good sized and one smaller pits develop once I got the shape where I wanted it to be so I tried my hand at filling. The fills turned out better than I expected for my first time. The smaller one is tough to spot but the other two are easy to spot but blend in decent. I mixed up some wood glue, briar dust, and clear lacquer for a filler and am fairly happy with the results. I'm guessing that combination has been used before. I'm having fun experimenting and trying new things.kkendall wrote:Well done! Symmetry looks good.
The only thing that catches my eye - and it may just be optical gymnastics - is the stem/shank joint. Looking at the side shots, it doesn't appear to be perpendicular at the joint.
http://en.wikipedia.org/wiki/Cyanoacrylate
aka Superglue
aka Superglue
Don't sweat it, your method seems to have worked very well.wdteipen wrote:Ah, yes. I thought about that but was concerned that the superglue would dry too fast. What are your thoughts? Does a superglue/briar dust mixture dry quickly?
Very nice symmetry to the pipe.
Thanks for the input fellas. Great observations and advice. My dissatisfaction with the gap between the stem and white lucite keeps this one off the market. I haven't decided if I want to smoke it or gift it to a friend. I don't mind flaws in the briar since, in large part, that is out of my control but I have to get better at facing my stems and treatments squarely.
