Some walnut pipes
Some walnut pipes
Thought I should post the last two pipes I've made, both of walnut scavanged from the badlands of Sunol, Ca.
Let me know what you think. They're in my gallery, anixihartz pipes/Walnut Pipes
Flix,
Let me help you out here. I saw your comment in another thread that no one had commented on your work, and you concluded that no one liked it. I have no idea if that is true or not, but I can say you be helped by making it easier to see your work. I opened your thread, saw no link and no pictures, and moved on. Making it easy to review your pipes will get you more reviews.
Here are Flix's pipes:
- achduliebe
Hello Flix,
I really like the shape of the first pipe, but seems to my eye that either the outside diameter of the bowl needs to be greater or the width of the shank needs to be smaller. With respect to this I am talking about the picture of the top view of the pipe. I also think the 'heel', so to speak, is to sharp. That is the transition from the bottom of the tobacco chamber to the front side of the tobacco chamber. Almost like a sharp 90 degrees there. I would make that more subtle. This is best seen in the side shot of the pipe. I do however like the shape overall. The shank, just past the shank/stem junction, appears to have a slight hump. Once again, I really like the shape of that pipe.
As for the poker, I really like that pipe and the only thing I see on that one is the stem/shank junction. Looks a little rounded on the shank side.
Overall, nice work. I have never worked with Walnut and I like the dark spots in it. Gives a very nice earthy natural feel to the pipes.
-Bryan
www.quinnpipes.com
www.quinnpipes.com
Thanks for the tip, Tyler. I was just kidding around, actually. I was going to link the pics later, but, got sidetracked by life.Tyler wrote:Flix,
Thank you for putting the pics up!
--Michael
Hi Bryan,achduliebe wrote:Hello Flix,
Thank you so much for your comments!
I see what you mean about the stem needing to be more narrow. I mistakenly thought that the flow of the stem and shank should taper. The bowl is narrow because I miscalculated when I roughed in the shape with my belt sander (oops!). I'll have to be a lot more conservative with the bandsaw from now on, leaving more room to maneuver. The heel was because of a series of flaws that caused me to have to dig deeper and sharper.
The hump is a little distracting also. I was trying to make it a Hawksbill, and this is the best I could do. I didn't think it was a huge issue, so I will need again to be more conservative with the bandsaw.
The stems I'm producing, from premolds, are not up to snuff. The Pimo tenon tool is not very good. I think I will have to cut my own stems, as soon as I can afford a lathe. Thanks for noticing that.
I'm not sure what you mean about the shank on the poker being rounded. Do you mean that the top is a little off? or are you saying that the bottom is also. I do detect the slightest dip in the top of the shank, near the bowl. I guess that would again be taken care of with the use of a lathe.
I suppose my work will look amatuer until I get the correct tooling.
I do like the bark features also. They are kind of a unique stamp of earthiness on the pieces. I will try to include something like it on walnut pipes in the future, if it works well. Too much of a good thing, though, isn't good...
Thanks Bryan,
--Michael
- achduliebe
Hello Michael,
The rounding that I was referring too was at the stem/shank junction. It looks a little like the stem is rounding down as it meets the shank. Which makes the junction there not be quite as clean, it breaks up that line. This rounding usually happens when you buff the stem when it is detached from the stummel. This could also be a result of the pre-molded stems. Other than that everything looks good to me. I think the shape of the stem on that pipe looks very good.
-Bryan
www.quinnpipes.com
www.quinnpipes.com
No, I didn't cure the wood, just let it sit in my basement for a while. How do you think one should cure black walnut? I'm stumped as to how (why?) ...ckr wrote:Normally don't care for pokers but the wood and it seem to go together well.
Couple of questions. Did you cure the wood and how does it smoke compared to a briar pipe?
I've smoked a few of my walnuts. They seem to smoke pretty well. I've not heard of many carvers using it though. I've heard far more using cherry, mesquite, wild olive, and one that escapes me for the moment (used for fence posts somewhere, some exotic name).
Thanks for the comments. I really like how the wood came alive between the time it was roughed in and finished. I'm working on a freehand in walnut as we speak. It drilled nearly perfectly and I've got high hopes for it.
--Michael
Popular hardwoods are Cherry, Olive, and Osage Orange. In addition, Johan Slabbert uses African Blackwood, Mopane, and Hookthorn. I have made a few out of Maple and Ash with all wooden stems, which work incredibly well for the SCA crowd that are primarily looking for display pieces or occasional smokers.flix wrote:I've smoked a few of my walnuts. They seem to smoke pretty well. I've not heard of many carvers using it though. I've heard far more using cherry, mesquite, wild olive, and one that escapes me for the moment (used for fence posts somewhere, some exotic name).
Just for the record, Red Oak isn't good for pipes. It does make a decent stem though.
That's "Bois d'arc", or osage orange, which Kurt mentioned.one that escapes me for the moment (used for fence posts somewhere, some exotic name).
I think they pronunciate it "Bo Dark" down in Texas.
Tyler may be able to help out here.
There's a line in a song by James McMurtry (Larry's son) by the title of "Choctaw Bingo" that has an interesting reference to "Bo Dark".
You should google it.
RadDavis wrote:That's "Bois d'arc", or osage orange, which Kurt mentioned.one that escapes me for the moment (used for fence posts somewhere, some exotic name).
No, Rad, we don't call it "Bo Dark."
We call it "boat ark."
Sheesh.
pnonetically? In Texas we spell that "phonetically." :dunno:RadDavis wrote:Sorry Tyler, I was spelling it pnonetically. I didn't know it was spelled "boat Ark".No, Rad, we don't call it "Bo Dark."
Did Noah make his boat ark from osage orange?
Man, I really need to get out more. I never realized all the things we do incorrectly here in Texas.
:thumb:
As for Noah, he used gopher wood. Is an osage a gopher?
ckr wrote:Tyler,
Hmm, I think that is a fairly common misenterpetation of scripture. I think that Noah was always saying "Go fer wood" and it was just misconstrued. Recent coptic writings have clarified this fact.
