First pipe from a block
miscoipipes
Re: First pipe from a block
Post by miscoipipes »
pipedreamer wrote:Very nice work for a second pipe. Aldens words are golden, make the same pipe at least twice, more would be better. It will pay off in the long run!!!
Thanks for an advice! Now I can see the reason why I need to to make the same pipe again and again :)
Alden
Post by Alden »
Charl, you are exactly right, I shouldn't try to speak in foreign measurements like "millimeter". Two of those things is way too short. More like a quarter inch or 57 rch's.
I agree with Alden's assessment. The only thing I would add is that the bowl could use more material removed. As it is, the bowl looks heavy for the diameter of bamboo that you used. That and the stem could be a bit thinner. Very nice pipe though. Closer to excellent than most first pipes.
miscoipipes
I will make the same pipe again, thanks :)
miscoipipes
wdteipen wrote:I agree with Alden's assessment. The only thing I would add is that the bowl could use more material removed. As it is, the bowl looks heavy for the diameter of bamboo that you used. That and the stem could be a bit thinner. Very nice pipe though. Closer to excellent than most first pipes.
The bowl is heavy because I was afraid to remove more material :) I also made the stem slot too wide and was afraid to sand into the airway.
I will definitely make my next stem thinner, thanks for the helpful comment!
miscoipipes
Thanks to everyone for the critique and helpful advises!
I will do as you all suggested and make the same pipe again (bamboo briar billiard). I hope the next one will be more refined :)
I don't have a good bamboo rod but I'll try to use what I have to make it looking Ok... The next pipe is coming... :)
(225.34 KiB) Downloaded 46 times
Dimitry I sent you a private message, you haven't noticed it (or are ignoring it, probably wise!). :lol:
miscoipipes
Sasquatch wrote:Dimitry I sent you a private message, you haven't noticed it (or are ignoring it, probably wise!). :lol:
Oops! I didn't see it, sorry. I will send you a reply in a couple of hours from my workplace :) Thanks!
