The 7mm to 9mm was referring to the 1/50 tapered reamer. Just to keep this simple (for me) that means for every 50mm on the x-axis it would go up 1mm on the y-axis, right? If thats the case then it should be a 100mm reamer. I looked at a gradient to degree chart and that would put the half angle of the taper at over 1°( 1 ° is a 1/57.29 gradient) , so a total angle of under 3°. Is this a suitable angle for a military mount?oklahoma red wrote:7mm at the tip and 9mm at the "end" over what distance? You need to know that so you can calculate the true angle. Perhaps the angle is stated in the description of the tool?kamkiel wrote:I have been looking at tapered reamers online in China. They have two basic tapers: 1/20 and 1/50 (gradients). From what I was reading in one of the other threads 1/20 (~5○ if I remember correctly) would be too wide of an angle, so I would go with 1/50. An 8mm tapered bit is the says the diameter is 8mm in the middle of the bit with (for example) a 7mm diamter around the tip and 9mm diameter at the end. I just want to verify, I should buy one with a tip diameter of 8mm if I want around that size of a mortise, right? Then find some tubing that would fit the outside diameter of my drilled mortise?
I am going to try this first if you guys think it sounds right. Later I will see if I can make my own mm(military mount) tool.
If I cant get any of these to work right, I'll just go the Alden route and start removing the stamp markings off of other people's mm pipes
Thanks,
Kiel
If the reamer you describe works out to be the correct one then drill the mortise first with a 7mm straight bit then follow it up (carefully!) with the tapered reamer. Leave as much meat as you can inre the shank diameter to reduce the possibility of splitting when reaming, then turn to final size.
Just to be clear, you do realize that the metal shank cap is for reinforcement of the joint? The taper is in the wood. If your shank diameter is big enough you can make a sleeve out of just about any material you want, exotic wood, acrylic, horn, etc. Whatever the material, its primary function is to protect the joint from the wedge forces of the tapered stem.
Thanks,
Kiel
